Hello everyone, I am hoping your combined brainpower can help me figure out this issue that the internet and several Volvo dealerships can't.
I got this 850 NA off Craigslist about a month ago. It is a base model 5spd M56 B5254FS 4.4 with California TLEV emissions (found this out because it needed a cat). Apparently it spent time in the Netherlands because it has holes for a longer license plate, a "NL" sticker on the back, and Dutch Kroner coins under the seat. I am in the US.
The car has this small key that needs to be inserted into a switch on the dash before it can be started. There is a red LED that blinks constantly until you insert the key, then it stays on. The switch has five wires coming out of it. See attached photo. It does not have keyless entry or an alarm. I only have the single 210 relay under the steering wheel and no receiver behind the glovebox.
It had stickers on the rear windshield and rear doors; they were triangular with a stick figure in the middle with lightning bolts around it with Swedish words printed on the perimeter. They were very faded and like an idiot I scraped them off so I can't get a picture.
Talked to 3 Volvo techs and they had never seen it before, VADIS doesn't show anything. Can anyone help?
1997 850 Mystery Ignition Key
- Has thanked: 2203 times
Not entirely sure, but I had a 93 850 NA which had a strange flat key like a small circuit board with a bunch of slots/contacts in it. It was an immobiliser and a major pain. I ended up removing it and solder the wires to by-pass it altogether. Car ran better with it removed as it would disconnect with age and slide out while driving. Also had another car in Europe with a ignition cut-out hidden at the back of the glove box. It had a similar type of key.
The purpose is as an ignition cut out I believe, so if you remove the key, the car won't start.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I think your system is on page 4.51:
http://accessories.volvocars.com/Access ... _NL_DE.pdf
Hope this helps!
Hope this helps!
THANK YOU! Its exactly what I have. Has to be a European model; Volvo of North America couldn't even find my VIN.BEJinFbk wrote:I think your system is on page 4.51:
http://accessories.volvocars.com/Access ... _NL_DE.idf
Hope this helps!
Where did you find the catalog?
- BEJinFbk
You mean This catalog?
http://accessories.volvocars.com/Access ... .D/Details#
Lotta cool stuff, but most of it is long out of production...
- Been thanked: 4068 times
Be careful you don't clog up the works..
That's a terrible pun, but funny never-the-less!
The system I had was fairly simple, and mostly just removed the live feed to the ignition switch. Pulling the key basically caused a break in the circuit.
Most of these older basic systems are fairly simple, but they can take time to figure out where all the wires go. Use a good wiring diagram and once you figure out where all the wires go, we can try to help to work out how to remove.
