1992 240 dl automatic 132,000 miles/overdrive switch
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
rontof
Year and Model:
Post by rontof »
Hi All
My transmission will not shift into overdrive. The button on the shifter does not seem to work and of course the arrow on the dash is on. Funny thing is that once in a while it will shift in as I'm going along.
Am I doing any harm by driving the car 55 mph if I'm not in OD?
Thanks
Ron
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
First thing to check is the overdrive relay. This is located behind the centre of the dash to the left of the glovebox along with the central lock and power windows relays.
I can't remember which is which but if you pull them out one at a time and try the lock and windows you should be able to find the overdrive relay by elimination.
Try giving it a good hard flick with your finger. This sometimes encourages a reluctant relay to work.
Edit. It is the relay on the right.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
