Replaced the blower motor tonight on my 91 940 with a used motor I got from a Volvo mech in town. Got car back together and now the AC button flashes and blower motor does not work. I have some sort of ECC error. Any ideas?
Thanks
Doug
1991 940se ECC light flashing
dougnelson
- Year and Model: 1991 940SE
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Snippets:dougnelson wrote:ECC error. Any ideas?
1. "SELF-DIAGNOSTICS - The Electronic Climate Control (ECC) control module can
detect faults in the system and store Diagnostic Trouble Codes (DTCs).
If a fault is present, system informs driver by flashing AC OFF and
REC switch LEDs for 20 seconds.
A fault warning is given when a fault is discovered or
present each time ignition is turned on or engine started. DTCs will
remain stored until cleared by an input code."
2. Volvo 960 climate control & heater system repair manual
dougnelson
Thanks a lot. I will give this a try.
Doug
Doug
dougnelson
Went through the Self Diagnostics and got error code 233 (Fan Motor Excessive Starting Current) any ideas of where to start. The blower motor was going bad and I replaced it with a new one and now I'm getting this code and the fan will not work at all.
dougnelson
Brand new out of the box. I guess I could check it vice assuming it works. Thanks
Doug
Doug
- 93Regina
I'd check current draw on fan with 12 Volts going to it. I would suspect there are some resistors on a board somewhere, maybe a resistor has shot craps, and/or the fan switch is bad. I know nothing here.dougnelson wrote:Went through the Self Diagnostics and got error code 233...
Is there a relay involved...it might be the issue.
Tidbits: Heating and Air Conditioning
- 167 Views
Last post by AlanHMultiV70s
- 1333 Views
Last post by jreed
