95 850 turbo , smoke from dipstick tube?
chrisjm91
- Year and Model: 95 Volvo 850T5
Re: 95 850 turbo , smoke from dipstick tube?
The project has come along great! Im cleaning all the parts and reassembling tomorrow. Any suggestions on a DIY intake manifold cleaning?? Its soaking in oven cleaner right now.
- Has thanked: 1500 times
- Been thanked: 3812 times
Eeeks...oven cleaner is kind of harsh..it's lye (extremely strong base, the same nasty stuff McDonaldsd uses to remove skins from French fries)
- Year and Model: Lots
- Been thanked: 128 times
Throttle cleaner is pretty good with baked on stuff however whatever carbon is in the manifold will likely stay in there and not do amy harm.
I always thought french fries were skinned before cutting them. Guess potatoes must be a little longer and squarer over there!!
McDonald's sell great bottled water!!
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
It really depends upon how far you want to go when cleaning items such as the inlet manifold:
Taken to a silly level like I did a couple of years ago, removed all the marks left over from the casting process then a fair few hours with wet-n-dry followed by extensive use of metal polish applied with a dremel and polishing wheel:
Installed it is better than the original lump of oxidised aluminium but is it worth the 80+ hours of work to get it to this level of clean
- Mike
- Mike
chrisjm91
Well ive got it all put back together and cleaned up. I took it for a test drive after triple checking everything. Performance wise, it runs the same, starts quicker tho. But the dipstick tube still has a light smoking action and oil spewed all over my clean parts (@#$& it lol!) I followed each step given and cleaned any and every part, hose, hole and orifice I came across. I can only think that maybe the oil trap/separator needs replaced not just cleaned and maybe the same with the nipple piece on the turbo hose? Please help!
- Has thanked: 292 times
- Been thanked: 765 times
Did you clean out the drain port into the block, at the bottom of the oil trap?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Ben850
- Been thanked: 7 times
Definitely clean the PTC nipple near the turbo on the intake tube.
That is where most of the pressure goes. Some drill it a little wider.
Many replace that hose with a "5/8 heater hose. I have done that on two already.
My Turbo Wagon was recent, and I bought blue heater hose to match all the new silicon plumbing.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- Been thanked: 467 times
Did you follow this 5/8-inch heater hose DIY below:
https://www.matthewsvolvosite.com/forums ... hp?t=53448
PS: Cleaning the engine port is OK, better yet, get a hose, connect to the lower port and blow through it, you should hear gurgling sound from the air you blow in.
