1997 850 5dr air conditioner wont cool
dreaminofonly1
- Year and Model: 1997 850
In my 1997 850 station wagon body, my air conditioner just blows out hot air. I was told to recharge it, so I did and it worked for a day or two than wont work again. I have a child and being out in 106 degrees is not good for either of us. I need to know a easy way to fix things because I do not know anything about this car when it comes to repairs.
- Has thanked: 1507 times
- Been thanked: 3822 times
The most common AC break is clutch gap wear which stops the AC compressor from turning when requested by the control unit. The internal gap adjustment (with shims) is expensive but the "bread clip fix" is not.
The next failure is evaporator core leakage. This is a 100 usd part but the dash had to be taken out to replace...about 8 hours of labor, so it is a 1000 usd job
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Has thanked: 293 times
- Been thanked: 765 times
If it was a clutch gap problem then recharging it would not have done anything.
Unfortunately, this is almost certainly a leaky evaporator core.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 403 Views
Last post by basilhenriques
- 33 Replies
- 4389 Views
Last post by PeteB
