99 S70 - It's summer annnnnd my AC isn't cold anymore
Auburn T5
Year and Model: 1999 S70 T5
Re: 99 S70 - It's summer annnnnd my AC isn't cold anymore
Post by Auburn T5 »
Well we got it figured out. It wasn't the evaporator (thank goodness) but rather the pressure switch had warped.
http://www.fcpeuro.com/products/volvo-a ... h-30767231
A pleasantly nice quick fix and the ac is ice cold now.
My mechanic took a peek at the evap from behind the glove box and he said it still looks to be in great shape.
He did discover that the exhaust manifold gasket is coming apart and I've got a leak there (which I kinda was guessing but he confirmed) so I'm going to be getting the copper gasket, an R manifold and *maybe* an ARD spool control 19T and tune :mrgreen:
First order of business before I go there is to get some supplemental transmission cooling in place.
2020 - Tesla Model 3 Performance
2020 - XC60 T5
1999 S70 T5 - Bilstein touring shocks/struts, B&G S2 springs, OBX full exhaust, other misc. stuff
Has thanked: 1505 times
Been thanked: 3818 times
Nice. I did my evap core on my 1999 last year, and held my breath this year the first time I punched the AC button - and it works great.
I have been spoiled my new-to-me P2 car which kicks out almost 50F of AC temp differential - it is ice cold.
Has thanked: 292 times
Been thanked: 765 times
Nice easy fix, good to know about the pressure switch.
Just FYI, the mechanic can't tell anything by looking at the evaporator core. Even when it is leaking he can't tell anything unless he uses tracking dye. Clearly yours is not leaking and that's good news, but still keep the usual close eye on it.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
You can actually see the track of a leak in the evaporator without dye because it will bring some PAG oil with it. Any greasy residue is either dead rodent or leaky AC. If it doesn't smell, its leaky AC. Once the grease gets on the evap core, hair and dust stick to it and it will look furry. If it has eyes, it might be a dead rodent...Swedish mouse or Norway rat..
Dye (which you can buy as R134A+dye at an auto parts store, will be easier to see.
Auburn T5
Post by Auburn T5 »
^ yeah my mechanic mentioned the oil thing. He says that he typically replaces about 8~10 evap cores every year once it starts getting warm outside and people with old volvos start to discover their AC doesn't blow cold anymore.
He did say it was the first time he'd ever seen a pressure switch warp like that. The fitting that screws into the AC line was no longer perfectly round.
2020 - XC60 T5
erikv11 wrote:... Just FYI, the mechanic can't tell anything by looking at the evaporator core. Even when it is leaking he can't tell anything unless he uses tracking dye. ...
abscate wrote:You can actually see the track of a leak in the evaporator without dye because it will bring some PAG oil with it. ...
Aha, I didn't think to look for PAG oil residue. Makes good sense, thanks for the info guys!
'06 S60 R, 197k
