90 240 dl sedan. cannot find a cold start valve replacement.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
I checked VADIS, parts, and no part number is shown. If there is a part number, try googling it.r_ziots70 wrote:cold start valve or injector for my car.
I don't know if an injector shop could run cleaning fluid thru it; it could be done yourself: how to clean your fuel injectors (correct way).
- 93Regina
If a barbed banjo fitting could be found in same diameter as this Bosch 0280170032 (CJ50 ), chances are, this would work also.lummert wrote:Standard Ignition Fuel Injector Cold Start Valve part number CJ10
I've used carb cleaner, and compressed air to clean up injectors...have to pulse voltage to injector...
- 93Regina
His must be a working unit, since the pintle is leaking, or something is grounding out unit; pull plug.jimmy57 wrote:Delete it....ever grounds it to operate.
Gates Barricade Fuel Injection hose comes in different diameters; 225 psi working pressure rating
Bosch 0 280 155 746 Injectors are same lb rating as OEMs, and these are third generation Bosch; I'd consider coverting OEMs if cold starts become an issue, if cold start valve is removed.
sorry didnt have internet for along time. just now gettin back on here. still have the same issue. cold start injector is leaking. no junkyards to scavenge from. will however if we cant get the right part. take your advise to switch to bosch. can you give me a specific # on that bosch please? oh and we just found out the computer has been bad before we owned the car. the person who owned it forgot to tell us that. we live in a warm envirionment. do we really need that stupid injector??
- 483 Views
Last post by candice_joel
- 1351 Views
Last post by Ozark Lee
- 974 Views
Last post by Cees Klumper
- 1739 Views
Last post by xarlock667
- 10 Replies
- 2736 Views
Last post by ggleavitt
