Hello folks. Need some education on the need for a check valve at the "T" hoses to the headlight washers.
The line comes out of the pump to a "T". The straight line goes to the windshield and the right-angled line goes to another "T" check valve that splits to the two headlight wipers.
Why a check valve and why not just a "T" connector? The fluid pressure there won't be that much for fluid to flow back to need a 'checking' process.
2001 XC70 Why Check Valve Before The Wiper Holes?
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- Has thanked: 1506 times
- Been thanked: 3822 times
Is there a check valve on the windshield line ? If nit, I would guess they got switched by PO
Otherwise, its quirky swede engineering, or a nice way to give you a spare check valve.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
I would think they placed a check valve there because headlight squirts are lower than washer fluid reservoir, they would probably gravity bleed out until either fluid is out or at same height. I would also say that it's probably a one way check valve to keep fluid right there at the ready to squirt when command is given, otherwise it would take a minute for washer fluid to get there. There are "T" style check valves and built in check valves for windshield squirtersOka wrote:Hello folks. Need some education on the need for a check valve at the "T" hoses to the headlight washers.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Oka
Nope! The hose comes from the pump, to a "T". The direct line goes to the windshield and the perpendicular one goes to the check valve which goes to the headlight wipers.abscate wrote:Is there a check valve on the windshield line ? If nit, I would guess they got switched by PO
Oka
The headlight squirters has their own switch on the steering column but from the same pump with the windshield washer.draser wrote:Do the headlight squirters work off the same switch, or separate switch?
It would sense for the windshield hose to have a check valve, preventing run back, but the headlight hose to have a pressure valve - requiring positive pressure on the valve to open, to prevent gravity draining of the headlight washer. Are the part numbers on the two valves identical or could they be different?
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Then it sounds like you'll need a check valve so you won't have windshield and headlights sprayed at the same time.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Oka
No, there is only one check valve which is located just about one foot and half from the fluid pump.abscate wrote:It would sense for the windshield hose to have a check valve, preventing run back, but the headlight hose to have a pressure valve - requiring positive pressure on the valve to open, to prevent gravity draining of the headlight washer. Are the part numbers on the two valves identical or could they be different?
The line goes from one pump to a "T". The straight direction on the "T" goes to the windshield and the perpendicular line then goes to the "T" check valve splits to both head light wipers.
There is no seperate switch for the headlight washers, they come on with the windshield washers & the reservoir sits in the bumper below the right headlight (on left hand drive vehicles anyways) no gravity drain possible.
The idea of having check valves to prevent the entire line from draining back into the reservoir sounds most plausible to me, I haven't yet tried on my Volvo, but on other cars it took quite a while for the windshield washers to start squirting again after completely draining & refilling the reservoir.
‘14 BMW i3
‘09 BMW 535XiT
‘09 BMW 535XiT
- 207 Views
Last post by securisign
- 392 Views
Last post by OldSkoolMadSkilz
