1990 volvo 240
1990 volvo 240
Runs rough first thing then evens out after I give it some gas this will happen maybe a week or two then problem vanishes for months then will come back out of the blue act up then go away again doesn't matter if its winter or summer
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Mechanical, Electrical, and/or Fuel issue...???ivylynn wrote:Runs rough first thing then evens out after I give it some gas....
When key is switched to on position, does the fuel pump engage for a few seconds? If so, from now on, turn key switch to on position, listed for pump, then after two seconds, turn key to start position.
Schrader port on fuel rail - Does yours have one...if so, measure fuel pressure after key is switched on
- 93Regina
If yours has a Schrader port on fuel rail , try using a tire pressure gauge, when engine is cold. It may spray gasoline, so you might use a cloth around gauge.
ALSO _ http://cleanflametrap.com/transferPump.htm
