2004 v70 heat coming from floor board?
goldmandan
- Year and Model: 1999 S 70, 2000 V70
I am having some heat coming from the floor board (accelerator pedal area) The A/C blows out the vents as normal but I have some heat coming from the floor....... is it a rubber grommet from firewall to passenger area that came loose? I have not had time to look into this yet but want to be prepared of what i'm up against
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
that could be the rubber boot at the steering column that goes through the floor. heat from near the exhaust area could go inside the car. it has to be clipped in place to the floor with a large clip spring.
- Has thanked: 1497 times
- Been thanked: 3809 times
On P80s the heater core pipes run right by your right foot, and either the cover removed there us a lot of heat generated there, I haven't looked at my P2 yet to tell if it is similar.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
My first guess would be faulty exhaust(clogged cat) gets really hot if theres an issue. If u feel the heat directly from floor board a loose firewall grommet doesn't make sense, u would feel heat blowing on ur legs not a burning floor board...this is real dangerous if it's ur exhaust(usually clogged/defective cat).goldmandan wrote:I am having some heat coming from the floor board (accelerator pedal area) The A/C blows out the vents as normal but I have some heat coming from the floor....... is it a rubber grommet from firewall to passenger area that came loose? I have not had time to look into this yet but want to be prepared of what i'm up against
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Wouldn't a clogged cat set some code (like cat efficiency or something, you do not necessarily need to have the MIL on).
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
More than likely. Also you'll have some rattle coming from the cat. What is on the other side of floor board where you feel the heat? And are all the shields in place under there?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
- regent
1. One quick way to locate the heat source is using a temperature gun with instant reading (I got one for $12.50 at Harbour Freight). You want to turn off the blower and look for the warmest spot(s).abscate wrote:...a lot of heat generated there...
2. I am also thinkng of a possible malfunction of the temp. control damper (like staying partially open when commanded to fully close). Have you eliminated that?
2015 BMW 335i
2015 BMW 335i
- shiloh51933
If/when it gets really bad the o2 information should eventually activate CEL but in the meantime I would look in that area rather then looking @ firewall grommets for burning floor boards.regent wrote:Wouldn't a clogged cat set some code (like cat efficiency or something, you do not necessarily need to have the MIL on).
