Gah, blew up intercooler housing last night at 17psi Topic is solved
Year and Model: Lots
Been thanked: 128 times
Re: Gah, blew up intercooler housing last night at 17psi
Post by precopster »
Same goes for not snugging up the right hand intercooler hose on a 2002 XC70. I put mine together in the dark and had a hole about 6mm x 40mm where the hose wasn't seated. Car ran like crap but just like you say no codes.
I would have thought a boost sensor would have given it away.....
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
I was also wondering about that, with the blown IAC hose it had to run very rich... but also no code.
850 T5-R '95 auto Image
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
post pics of the FMIC setup when you get it! i love fancy gear.
i think you might be able to get the epoxy to seal up the crack if you epoxy something _over_ the crack - bang a sheet of thin aluminum over to shape it and clamp while it cures, or something to that effect. it would still be a temporary solution, but maybe you could treat yourself to a few extra psi. and if you polish the aluminum, you can tear off the bottom of the bumper and pretend it's an FMIC until you've got the real deal going.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
j-dawg wrote:post pics of the FMIC setup when you get it! i love fancy gear.
Will do.
j-dawg wrote:...and if you polish the aluminum, you can tear off the bottom of the bumper and pretend it's an FMIC until you've got the real deal going.
:lol: :lol:
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
To follow up on this and mark it Image Solved, I ended up replacing the intercooler with an OEM Volvo unit a couple months later.
Also -> Amazon link
cmblackburn
Year and Model: 1998 S70 T5M
Been thanked: 7 times
Post by cmblackburn »
Ouch. What tune are you running? Also hi! First time I've been on here in quite a while.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
matthew1
Site Admin
Post by matthew1 »
Hi C. No tune. Just an "628" R ECU that probably doesn't make any difference at all. The boost comes from a manual boost controller I put on years ago.
Also -> Amazon link
