Coolant level indicator not working properly, 1999, C70
owenmpk
- Year and Model: 96 and 97 850 99 C70
The coolant level indicator on my 1999 C70 keeps comes on and stays on some day and other days does not come on. The coolant is full so that is not the problem. Before I start chasing all the wires down has anyone else seen this issue and a found cause?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I would suspect that the level sensor is faulty. This happens often on sensors immersed in water.
You could try removing the sensor and check to see if it is sticking at all.
There are only two wires going to it: 1 yellow and 1 black. The black is the earth (ground) wire. Check it for good connection.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
owenmpk
I fixed the problem by lifting the coolent tank out of its mount and shaking it. It has worked ok for the last 2 monthsbillofdurham wrote:I would suspect that the level sensor is faulty. This happens often on sensors immersed in water.
Bill.
- billofdurham
The easy repairs are the best. Probably the sensor was sticking.
Glad it is sorted.
Bill.
Glad it is sorted.
Bill.
Previously:
Previously:
- 444 Views
- 2855 Views
Last post by Georgeandkira
