1991 740 NA Air Conditioning -Intermittent, no leak
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
SkyVolvo
Year and Model: 04 S60 2.5T, 94 850T
Has thanked: 5 times
Post by SkyVolvo »
My '91 740 only blows cool A/C on occasion. It used to be regular, then it only worked sometimes, then only rarely. A year or so ago, I topped the system off with Enviro-Safe, and it was beautiful - all functional, all the time.
I drove the car down from Denver to Nashville and gave it to a relative, and this summer, the A/C got squirrely again. My first thought was that it needed a little extra charge, so I added a little, thinking that maybe it was just shy of what it needed. This did nothing, and it looked like it had PLENTY of pressure. It was another few weeks before I was able to even take a look at it again, and in the interim, it occasionally cycled on and blew cool.
The next time I looked at it, the pressure still seemed very high, so I wondered if it actually had too much pressure for the compressor to kick on. I released a little bit, and behold - the compressor started cycling. I eased it back up to the right fill for the outside temperature, sat in some lovely, cool AC for a minute or two, turned the AC on and off a few times for good measure and went inside.
Anyway, I went back out to move the car a little later and no AC. The compressor was not engaging. It clearly does work, and the system clearly has refrigerant in it. It just doesn't work on command. Is this likely to be a clutch gap issue, some type of relay somewhere, a switch - what am I not looking at that I should be?
Thanks!
UPDATE: Measured the clutch gap at .030 inches (.762mm)
Current Volvo:
2004 S60 2.5T
Volvos Emeritus:
'94 940
'91 740
'94 850T Wagon
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
SkyVolvo wrote:The compressor was not engaging.
With a wiring diagram, one follows backwards from AC-compressor.
On a 240, for instance, there is a pressure sensor; so at that junction, one injects 12 Volts, and listen for AC-clutch...no clutch noise, then go direct to compressor with 12 volts.
