hi
is there a way to by-pass the immobilizer on a v70 tdi? there is no diesel going out the injectors, the pump is closed, i tried an other immo and antenne ring and transponder but doesn't work,
thanks for an answer
1998 v70 tdi immobilizer
- Year and Model: Many Volvos
- Been thanked: 75 times
On a '98 I don't think so. On the 850's it was easy but in '98 they changed the system and I think it talks to the ECU via a digital pulse train rather than a closure. I don't have schematics for the diesel version of the car though and I could be wrong.
VOL-FCR and a VAG COM cable should allow you to check the immobilizer on a '98 for fault codes. The program and the cable are readily available on eBay and it is typically very inexpensive.
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
I can't help you with the bypass.
Just wanted to say I'm very glad to see someone here on MVS using Brick-Diag.
Are you using Brick-Diag Free v0.0.6.6?
Or do you somehow have access to Brick-Diag Full?
esl_97_850_T5
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
