Greetings fellow Volvo enthusiasts,
I have owned this vehicle since Nov of 2013. Since the purchase, in this order I have replaced:
-ABS module
-Throttlebody cleaned
-New clutch installed
-New radiator
-New air pump (was supposed to get rid of CEL but didn't)
-New battery
After replacing battery, the door locks lock and unlock by themselves at random and the trunk unlocks itself as well.
Any insight would be appreciated.
Thanks Team!
1998 S70 Door and Trunk locks work by themselves
- Year and Model: Many Volvos
- Been thanked: 75 times
Many times a dirty door switch or a sticky lock mechanism will cause the locks to cycle. Try locking and unlocking the door and the trunk, with the key, several times. Sometimes you can get lucky and that will loosen the locks up enough that it starts to work again.
sconus
- Year and Model: 1998 Volvo S70 Base
Here is an update on my post.
I can lock/unlock driver door with key.
I cannot lock/unlock all doors by moving key twice to left or twice to right.
The lock/unlock all button on the power window switches (master/passenger) does not work.
i can only unlock all doors except driver door with key fob.
All doors lock with key fob except driver door.
Trunk continues to randomly unlock when I am away from vehicle.
I hope this narrows it down a bit.
- Has thanked: 1505 times
- Been thanked: 3817 times
was this just the door lock switch replacement or did you do the window switch too?sconus wrote:The random locking and unlocking issue has been solved! I replaced the passenger power window power door lock switch and that did the trick.
