After you run the car, and come to a stop or low idle and the no oil pressure warning light and warning message come on.....if you give it even a tad of gas message goes away???
Bad sending unit or sensor?????
Just changed oil and filter today.
2002 s60 2.4t no oil pressure warning
horseguytenn
- Year and Model: S60 2.4T 2002
- Has thanked: 1507 times
- Been thanked: 3822 times
My 1999 owner manual says it is ok if the light comes on after hard driving, as long as it goes out when revved. Check your manual for the same language.
At idle, the load on the bearings is very low, and as long as some oil is reaching the bearings,you will be fine. If you know you have kept the oil level up and made regular changes, stop worrying about it.
Are you running synthetic oil...type and weight??
- Year and Model: Lots
- Been thanked: 128 times
Sounds like oil pressure could be better on that car if you're just driving normally.
Typical culprits are the sump o ring seals which can crack an cause a loss of oil pressure. Post 1999 cars have solid lifters so you won't hear any tapping noises when the o rings are in need of replacement.
Is last known replacement of these seals or service history available for your car?
From the 2002 S60 manual, on the oil light
After hard driving, the light may come on occasionally when the engine is idling. This is normal, provided it goes off when the engine speed is increased.
Sure however OP is not driving hard. Normal driving shouldn't create this condition. Check oil pressure with a guage. The only situation when this is normal is if idle speed is too low.
- 1153 Views
Last post by Salomons Driveway
- 292 Views
Last post by Cmunive
