1998 s90 I like to punish my self!
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Jesse8931
Year and Model: 98 s90
Re: 1998 s90 I like to punish my self!
Post by Jesse8931 »
I'm getting a new trans filter today so I will drop the pan change the fluid and filter and see where I'm at. Here is the thing when the trans is cold the car shifts great I can drive it for 15ish mins then it slips like crazy.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Jesse8931 wrote:trans is cold the car shifts great I can drive it for 15ish mins then it slips like crazy.
I assume there is a means to do a line pressure check; I would not drive it slipping.
When I rebuilt a B23F, and slipped it into a 93-944, I renewed the AW71L's oil pump ($100.00), and installed a rebuilt torque converter ($150.00).
I know nothing of those electronic transmissions, but I would suspect either a kit and oil pump is needed, or if it has PWM, I'd check to see what it is doing, percent time, if applicable.
Jesse8931
Post by Jesse8931 »
I have only tried to drive it around the block. It does throw a code p0740 lock up solenoid circuit open.
Jesse8931
Post by Jesse8931 »
I've got an update!
I pulled the pan cleaned the crap changed the filter and put new fluid in and she is working great!
93Regina
Post by 93Regina »
Jesse8931 wrote:changed the filter
Screen? Or a Filter? Dirty?
Jesse8931
Post by Jesse8931 »
I changed the transmission filter and 7qts of fluid.
Jesse8931
Post by Jesse8931 »
OK 300 miles in no cel Trans is shifting fine. I just ordered a timing belt kit. So it looks like I got lucky as hell!
Jesse8931
Post by Jesse8931 »
Another update.
I have driven the car for about 1000 miles and plan to do another trans fluid change.
I now get a p0410 code and have found some leaky vacuum lines.
Where can I get the u bend parts for the vacuum system. I can get hose no.issues but the u bends are dry rotted and leaking as well.
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Give FCP a call and they can help with all of this. Your local Volvo dealer may be able to help too. I used regular tubing to replace some of my elbows. A few are different sizes on each end. FCP is generally very helpful.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Jesse8931
Post by Jesse8931 »
Another update.
I've drove about 2k and last night I drained the pan again 4qts. Fluid was brown so that's 3 times I have drained the pan.
while I was draining the pan I removed the negative battery cable to reset the ecu and tcm.
I also changed all the vacuum lines and checked the air pump and it's working yet I am still getting the p0410.
