2006-xc70. So I did a tranny drain and fill -2x- second one about 150 miles after #1....Now checking the level. With motor RUNNING...it's slightly below the hash mark...maybe even on the bottom one for HOT. The fluid is so clear that it's tough to tell where exactly the level is when running..
With the engine OFF...NOT running (yet very hot)...it's waaaay over the hash mark. So, just for peace of mind...check with the engine running, right? I don't want to get too nutty about the level...but I don't want any 'issues'.
Checking tranny fluid level
JRL
- Year and Model: Several
- Been thanked: 16 times
Answered on SS
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Engine must be running. If you barely see fluid on the stick, then it's probably that there's no fluid, just smear off the inside wall of the dipstick tube. It should be a nice thick droplet of fluid.
Have the car driven for a good 30 minutes or more. The transmission fluid needs to reach it's operating temperature.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
What brand ATF are you using? I recently copped another Volvo('04 XC70) and have been doing drain/fills even though 1st owner(previous owner has provided all service documents) w/atf flush service. Before I totally flush I'm doing about 5 drain/fills(did 2x), I use Febi 29934 which is JWS3309 equivalent. Have u noticed a difference yet?AlanS wrote:2006-xc70. So I did a tranny drain and fill -2x- second one about 150 miles after #1....Now checking the level. With motor RUNNING...it's slightly below the hash mark...maybe even on the bottom one for HOT. The fluid is so clear that it's tough to tell where exactly the level is when running..
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- Year and Model: Lots
- Been thanked: 128 times
Clean new fluid is hardly visible on the stick. Most people are content to see a red colour on the stick after 2 or 3 drain and fills (around 11 quarts) It actually takes around 16 quarts of drain and fill to have 95% clean fluid.
- shiloh51933
I wish I had this issue of crystal clear atf...I've completed 2x drain/fills w/Febi ATF(#29934)JWS3309 compatible. I'm getting ready to order some atf from FCP for both of our Volvo's but haven't decided if I'm going to go with Aisin ATF-OT4 or Mobil ATF3309(these 2 r much cheaper than the Febi 29934). What about this Idemitsu ATF Type-TLS? The Idemitsu ATF is much cheaper than all the rest, so if it's any good it might be worth ordering some. Any feedback is appreciated, thanks.precopster wrote:Clean new fluid is hardly visible on the stick. Most people are content to see a red colour on the stick after 2 or 3 drain and fills (around 11 quarts) It actually takes around 16 quarts of drain and fill to have 95% clean fluid.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I ordered 2 of these some time ago, good price I think.
https://www.amazon.com/Mobil-55221-Autom ... words=3309
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
These guys http://www.avlube.com/mobilatf3309.html offer a case for $62.73 plus shipping (the total may even beat amazon's price plus tax for your state)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Is it cheaper? If I remember correctly, it is slightly above of what I have to pay for Mobil 3309.shiloh51933 wrote:What about this Idemitsu ATF Type-TLS? The Idemitsu ATF is much cheaper than all the rest, so if it's any good it might be worth ordering some. Any feedback is appreciated, thanks.
Anyways, I use Type-TLS in both P2s our family has. They guy, who replaced the valve body in one of them (2002, was already problematic when I bought it 4 years ago), said he found that Idemitsu works best in AW55 in Volvo. Otherwise he uses Mobil 3309 for AW55 in the rest of cars.
- shiloh51933
Nice!! That's $5.80 a quart for some top shelf ATF, I'm sure your satisfied with the Mobil 3309 ATF. Originally when we first got our '96 850 I drained/filled w/Mobil 1 Multi vehicle ATF which was compatible with that A/T. I've done the drain/fill process on the 850 twice over the last 5 years w/Mobil 1 Multi vehicle formula but this last time I've been using Febi 29934 since it's available @ the Napa by my house. If I can get a case of the Mobil 3309 for that price I'm going w/that stuff to complete the drain/fills on our '04 XC70(2 x drain/fills w/Febi).rmmagow wrote:I ordered 2 of these some time ago, good price I think.
- 9 Replies
- 1427 Views
- 789 Views
Last post by difflock54
