I have 180K on my S40 and think it needs a ATF change. Reading the forums here, I have a question:
Is it possible to check thr ATF on a 2001 s40 while the engine is running without having it be on a lift?
The dipstick is under the radiator hose and it appears to be inaccessible from above when the car is running due to both the radiator fans and the heat. Won't you burn yourself if the engine is at normal operating temperature?
Is checking it when the engine is cold good enough?
Thanks for any help!
-tom
2001 S40 Checking Automatic Transmission Fluid
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
My understanding is that it is better to check the transmission level with the motor/transmission at a hot running temperature but I don't think the engine needs to be running whilst checking.
That is how I do mine anyway, and from above but access is tight for sure.
- 3349 Views
Last post by pmondrian
- 1248 Views
Last post by ignatz
- 1187 Views
Last post by Krons
- 1863 Views
Last post by Caspar
- 1433 Views
Last post by RickHaleParker
