I was looking at the AC on a '95 850. The AC just quit yesterday. Seems to have freon in the system but the compressor will not kick on. I tried bumping the the front of the compressor, serving it a little, and even jumped the low pressure switch connector at the wire plug near the firewall. No action at all. It is MCC.
Any suggestions?
Is the AC fried on this Volvo 850?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
What's the low-side pressure with compressor not running?
Could be a bad relay, or it may just need the compressor shimmed.
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
Contact rspi..
My gauge is wacky but no freon would go in.
The clutch gap seemed real close. Likely good. I'm going to check for power at the low pressure switch.
I checked several relays, swapped a few around and back.
- Year and Model: Many Volvos
- Been thanked: 75 times
Hot wire the compressor wire to the + battery terminal and see if it kicks on then. If not, check the clutch wire for resistance to ground, if it reads an open circuit the compressor clutch is fried.
- rspi
Contact rspi..
Thanks guys.
I know of 2 wires coming off the compressor, the one in the white sleeve and the other smaller one. Are you saying that I should put 12v on the one in the white sleeve?
How do I check the clutch wire for resistance? Is that the small wire or the one in the white sleeve? Should the other wire be connected to it's plug?
- Has thanked: 1506 times
- Been thanked: 3818 times
Robert - one wire is a temp sensor and will end at a pot stuck somewhere on the AC compressor. The other wire will disappear into the guts of the compressor at the clutch. Thats the one to put 12 volts on. I would make up a fused (30Amp) test wire to do this in case you short it while testing. You can label it VOLVO AC CLUTCH TEST TOOL and sell it on ebay for 35 USD when done.
northernlights
- Year and Model: 850 Turbo 1994
- Location: Florida and/or Raleigh NC, depending on the day
- Been thanked: 8 times
The high pressure switch (near the dryer) will also keep the clutch from engaging. I don't know if that is normally open or closed.rspi wrote:My gauge is wacky but no freon would go in.
- rspi
Contact rspi..
I guess I can compare it to my car side by side since they are both '95's.
