1999 s70 battery drain
prospectortom
Year and Model: 1999 S70
Post by prospectortom »
My battery is draining overnight. I did a voltage check through the battery and found #6after fuse is the problem. This fuse handles Central Locking. Is there someway to disconnect the system somehow? When i pull the fuse i have no starter.
Braz
Year and Model: 1999 V-70
Post by Braz »
When our V70 started draining the battery we discovered that the courtesy lights were not shutting off. "Fixed" it by turning the cabin lights off with the switch and pulling the bulb units out of the door jams. We rarely drive the car at night anyway.
Braz
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
prospectortom wrote:My battery is draining overnight. I did a voltage check through the battery and found #6after fuse is the problem. This fuse handles Central Locking. Is there someway to disconnect the system somehow? When i pull the fuse i have no starter.
You did a current draw test on each fuse? Maybe one of the solenoids is stuck or shorting causing some leakage current.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 292 times
Been thanked: 765 times
I don't know what all runs on fuse #6 but as for central locking: do all of the locks seem to work properly, with the clicker buttons and the different buttons in the car? Unless you can pinpoint one of them as a likely culprit to unplug first, you may have to pull the door panels one at a time and disconnect the power to each lock, see if that changes the current draw. Could also be in the trunk lock I suppose, maybe that one is easier to try first.
Removing the door panels is really easy but expect some clips to break. The clips are expensive from the dealer or parts houses, you can put the panel back on with fewer clips or sub in cheap Christmas-tree style clips from the parts store, if you hunt around for the right size. The other thing that happens sometimes is the little blocks that hold the clips on to the door pull off, they basically come unglued. This is actually easier to deal with than broken clips. I try to remove and install the panels as little as possible, they are 15 years old and something inevitably goes wrong each time they are pulled ...
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Gorilla Glue works great to re-attach the blocks. I bought a whole box of 25 clips that work either on line or at AZ. I'll check info on the box at lunch time and maybe it'll help me remember where I got them.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
How about a pic of the front of the box? Would be most appreciated!
'06 S60 R, 197k
prospectortom
When i pull the #6 fuse the amp draw stops. But then when i try to start the car with that fuse out i have no starter engaging.
Gotcha. So you need to find out which of the accessories that #6 supplies power to, is causing the excess amp draw.
It could be one of the door locks. Do they all seem to work right (see questions above)?
'06 S60 R, 197k
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Have you read the actual parasitic draw (amperage)? There are quite a few circuits that are fed besides Central Locking from that same source. You could put the meter across the fuse with the fuse out and read that way.
Is any of the aux equipment malfunctioning; have you tested all your courtesy lights if they turn on/off as they are supposed to, etc.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
prospectortom
Reading at the fuse(with fuse out)and unplugged door lock switch its pulling 1.6 amps
