hydraulic strut spring compressor
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
for several years I have used the two bar threaded strut spring compressor until I had one of the arms slip. I saw this unit on eBay for $120.00. here are some pictures of a strut spring under compression.
if you are in the Columbus Ohio area I would be glad to help with your struts.
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
That's the way to do it.
I have the clamshell compressor from HF. Those stick style ones scare me.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Has thanked: 1504 times
Been thanked: 3817 times
The trick with the sticks is to thread a piece of chain through each arm and then through the spring.
The other trick is to make sure you tension them evenly - and realize that since you generally don't have the same amount of spring on each, equal tension is not equal length of thread on the two sticks. Tension them to keep the spring looking straight, a little bit at a time. You only do this job every 100k miles, so take your time.
Once you do this, and wear heavy gloves , you really can't get more than a bruise.
Plan B is to take your parts to your Indy and have s/he assemble for a six pack
That is a NFT though, and it so easy to use, the dogs will sleep right next to it... :D :D :D
