DIY front end toe alignment?
chrisjm91
- Year and Model: 95 Volvo 850T5
Hey guys, I was wondering if anybody has come across the procedure to adjust the toe on a 95 850? I watched a YouTube vid of a guy aligning the toe on an older volvo but my tie rods are different from his. I know to loosen the lock nut, measure using a string or lines on the tires, and to reduce friction on the front end so the tires can slide in easier. But my question is what am suppose to turn to pull it In? Do I pop tue tie rod off and twist it in or can I just turn it with it still attached? Any advice would be greatly appreciated, thank you!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As mentioned above, it's the inner tie rod that turns to adjust the toe in - it has a notch where you can place a wrench to turn it. Remember, you always need to adjust both sides (left and right wheels) in such way that the steering wheel will remain centered. As a rule of thumb, if the steering wheel is only slightly off-center, turn the inner tie rod no more than 45 deg. then drive the car to check the steering wheel.
When finished, careful when tightening back the nut, as you might loose the adjustment. I always keep the wrench on the inner tie rod to see if it wants to turn. Don't over-tighten the nut too much, not needed and surely you will have to readjust sometimes later.
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
There's a 13mm hex on the inner tie rod. If there's no hex, just use pliers.
What did you replace or do that makes you want to do a home-brew alignment?
- Been thanked: 471 times
Yes turn the inner tie rod to adjust toe-in. You will need to heat with propane torch and use some PB Blaster because by this time the threads are seized in there (water, salt from winter etc.).
As long as you have parallel lines on the garage floor, then you are OK.
I wrote a DIY using plumb bob (you need an even garage floor), search for it.
I align my cars at home and have not been to an alignment shop for the last 10 years...
- Has thanked: 292 times
- Been thanked: 765 times
I have done some front wheel alignments myself, no issues there, but have not figured out how to avoid the shop altogether ...cn90 wrote:... I align my cars at home and have not been to an alignment shop for the last 10 years...
How have you aligned the rear wheels on your Volvos and other FWD cars? How do you make sure the front and the rear track together (check the thrust angle and adjust if/as necessary)?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
chrisjm91
Ok so I need to pull back the boot to find the notch or just take pliers to the open portion of the inner tie rod? The reason I am trying to align is that ever since I bought the car it has pulled hard right and thr INSIDE of my FRONT DRIVERS SIDE tire is wore way down. I rotated the tires from rear to the front and within a matter of days that tire was wore down on the inside as well. I measured yesterday using both string and tire line trick. What I came up with was an 1/8th inch off on both left and right tires, a 1/4 inch total.
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
If you have a significant pull and wear, then there could be a component that has been bent and the pull may remain even after your adjust the toe. Have you ruled out a bent control arm?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- RussB
regent wrote:If you have a significant pull and wear, then there could be a component that has been bent and the pull may remain even after your adjust the toe. Have you ruled out a bent control arm?
This.
everything looks pretty old in there. check the inner & outer tie rods and the ball joints
