2000 S80 Loss of power brakes
rerobin66
Year and Model: 2000 S80 T6
Post by rerobin66 »
Twice within the past two days I have had no power brakes while backing out of the garage. I stop the car turn off the motor and restart and have power brakes again. Any ideas?
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
rerobin66
Post by rerobin66 »
So of the many views and no solutions, and being the girly girl genius that I am.....it is a vacuum leak in a seal under the rubber boot on the cabin side of the power brake booster. This would explain why there are no warning messages from my computer. I removed the panel that covers the driver side area to access this side of the booster. After manipulating the rubber boot a bit I was able to stop the air from leaking. However it has to remain in that exact position or I hear it hiss air again. So I decided it must be a seal around the rod that attaches to the brake pedal that has dried out. Seems like such a waste to have to replace the whole booster due to leaking seal(s). Well for now I greased the rod and surrounding area to hopefully add moisture to it and I have no hissing, so I assume it is not leaking. The brakes still make a air release noise when pressed, but I think they all do that. Correct me if they should not. Perhaps someone viewing will at least know that!
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
jkdjim
Year and Model: S80 T6 2000
Post by jkdjim »
I have a similar problem and assumed it is a bad brake booster. They're $250 or so aftermarket so I'm just dragging my feet with replacing it.
rerobin66
Post by rerobin66 »
I am going to drag my feet too! And see if I have revived the seal so that it will hold pressure.....we will see!
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
rerobin66
Post by rerobin66 »
I really don't want to replace my power brake booster, but I know that is the issue. So I have clipped my nails to standard mechanic length and crawled under the dash, again. I have tightly wrapped the rubber boot with electrical tape to stop the air leak. We will see. And I have concluded that the best tools to work on my old Volvo are super glue and black electrical tape!
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
rerobin66
Post by rerobin66 »
Bit the bullet, no more dragging my feet! This girly, girls got this!
Volvo Brake Booster (S80 S60 V70) ATE 8649491
$151.11 1 $151.11
Order Total: $156.10
Subtotal: $151.11
Promotion (Loyalty Code: $5 off $149+) -$5.00
Shipping $9.99
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
lonestar245
Year and Model: S80 2002
Post by lonestar245 »
FCP Euro?
Let us know how the replacement goes. I have a vacuum leak in the brake system somewhere, and I am considering changing the booster in hopes that that covers all the possible areas for leaks.
edit: looking at brake parts for my 2002 S80- the booster is more expensive, and there are other potential problem areas for my issue- booster vacuum ejector, booster vacuum switch, brake vacuum pump, hoses... (shakes head)
jkdjim
Post by jkdjim »
Shit $150?! I thought it was $250 easily, even on FCP. I'm gonna jump on this sooner rather than later.
edit: anyone know when to replace the vacuum switch (31400692) and/or the vacuum ejector (30665561)?
Should I replace them with the booster, or could these be what are at fault?
rerobin66
Post by rerobin66 »
I had to go out of town. So hubby did the whole removal and install of booster. He said it sucked. But he did a great job. the only issue was that the brake failure warning and abs, and traction lights came on after he was done. Today, now that I am home, we pulled the ABS module off and cleaned it up and reinstalled, all warnings went off (gone) and it is perfect again!
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
