1999 S70 Wagon Roof Rails?
asummers
Year and Model: many
Post by asummers »
I was wondering if the roof rails from the V70 would fit the S70, if they could be shortened? Does the S70 have the bolt holes under the roof side rails? I know the S70 has the roof rack bolt holes inside the top of the door jambs. But, if a custom wagon roof rail is possible, that would be nice. Saw this video on youtube about the roof rail removal.
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
Steve Ivins
Year and Model: 850 t5 1994
Post by Steve Ivins »
On my 850 T5 sedan I removed the roof trims but there are no holes. I used Nutserts/Rivnits at 5mm to match the wagon screws. You can remove the ends and centre easily. A rubber mallet was used on the ends and there is a roll pin in each end. I discarded the centre mount and spaced the ends to line up with threaded holes at each door. In hindsight taking the ends more forward and rear would be the better option as the rear mount is longer and it sits high on a sedan. I hope this helps. The bolt holes are under the trim and got at from the top after removing 6 little pieces.
Cheers Steve.
asummers
Post by asummers »
I actually googled and found a picture of an 850 with wagon roof rails installed. Very interesting!
Steve Ivins
That looks better than my attempt. Mine start and finish mid door, too short. Will start again with another set and unmolested cover trims. Like I suggested, Move the front forward and the rear back and it should look sweet. Cheers Steve.
Steve Ivins
Damn, Why did I not do it that way first. Looks good.
Has thanked: 292 times
Been thanked: 765 times
Member yellow95 over at Volvospeed or Sweedespeed has done this with great success on a few S70s:
One of Gary's cars
One of Gary's cars
http://forums.swedespeed.com/showthread.php?174340-1998-S70-T5m-140-000-Miles/page3
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
dosbricks
Post by dosbricks »
The above photo made me :lol: --so vs/ss subculture.
