96 850 non turbo/ oil under the top cover
rogreact
Year and Model: 96 850 glt n/a
Post by rogreact »
I take the top cover off to expose the plugs and there is a lot of oil there. Where could that be coming from?
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
You need to replace O-rings in the spark plug wells. It needs to remove the camshafts cover. If you have no experience, you better to entrust this work to mechanic.
If my English is bad, please correct me :oops:
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
is the oil in the spark plug wells, or is it in the recesses along the cover? If it is primarily in the plug wells, see the above response, but if it is in all the recesses of the cam cover, especially between #2 and #3 cylinders, it is most likely from a bad oil cap seal, or the PCV hose. Either one indicates the need for PCV servicing that you will find in other threads here. When the PCV blocks up, pressure builds inside the engine, forcing oil/vapor through the weakest seals, how is the inside of the distributor behind the oil guard?
Current Volvos:
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
I think FLXC90 pretty much hit the nail on the head with oil cap seal and PCV needing service. If you search PCV system you will come across posts on how to evaluate your PCV system and also how to do the service. Member RSPI has several excellent videos on this issue.
rogreact
Post by rogreact »
can someone direct me to an article on how to replace flame trap. I have no idea how to do it. For 15 bucks I could do this myself and see if I solve anything
FLXC90
Post by FLXC90 »
go to the repair database and search the pcv maint. It will run you through all of it. You'll save the $15 by disposing of the flame-trap, but there is a little more to it than just that. Did mine recently, big difference.
Current Volvos:
rogreact
Post by rogreact »
If you throw the flame trap away what do you replace it with? A piece of hose? I am a novice
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
rogreact wrote:If you throw the flame trap away what do you replace it with? A piece of hose? I am a novice
Nothing. Remove it and put the hose back in to the throttle body hose - the "flame trap" is just a plastic disc that fits inside the hose that serves only to clog.
'98 S70 T5
2016 Chevy Cruze Premier
