Electricity completely out
Battery Corrosion Stopping Electricity?
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I edited your post to make it easier for all of us to see.
I have read about this same corrosion and shorting issue on other forums. I suggest that anyone who is having strange battery/electrical issues check this location at the bottom of their main fuse box (the triangular one).
MIJ
MIJ
Thanks, gotcha.cn2000 wrote:It's the triangularish box on the drivers front strut tower that houses many of the system relays, fuses and the main power feed from the battery. Remove the cover and you will see the nut I am talking about.
greasefingerss
- Year and Model: 850 wagon 1994
If I understand you question correctly, the battery charger is for the battery only and it is not for testing circuits and devices.
One of the best electrical trouble-shooting devices is a digital multimeter. If I could not measure voltage and resistance, then I would be lost. However, a 12v test lamp can be found at places like Radio Shack and HomeDepot, for about $ 5 USD. The lamp will tell if something is being feed battery voltage.
If you have not used these before then I would suggest that you find a friend that can give you some pointers. It is too difficult to explain electrical testing over the Web.
Current Vehicles
1994 Volvo wagon(855) na 161,000 miles with AT
2003 Toyota Camry
1994 Jeep GC 202,000 miles
2003 Toy 4Runner
2003 Toyota Camry
2003 Toy 4Runner
thanks, i know how to test with the lamp... what i was thinking was to use charger clamps instead - when i attach them to the battery the amp meter on the device shows resistance - isn' t it the same thing ? only difference i would not connect the charger to the mains.... (i am not expert/engineer as you may imagine, but not afraid to grease me fingers:) )greasefingerss wrote:If I understand you question correctly, the battery charger is for the battery only and it is not for testing circuits and devices.
bobsnow100
- Year and Model:
I think it is something with one of the battery cables also . For you to have no electricity leads me to believe this. If it was the key switch at fault you still would have your door locks working,inside lights still coming on when opening the door which you stated you don't. Don't forget to check you ground(-) battery cable also
greasefingerss
I still may not understand what it is that you are trying to do, but a multimeter works by applying a very very small amount of voltage to a circuit that is being measured for resistance. You cannot measure a resister without voltage (V=IR)lvrisk wrote: thanks, i know how to test with the lamp... what i was thinking was to use charger clamps instead - when i attach them to the battery the amp meter on the device shows resistance - isn' t it the same thing ? only difference i would not connect the charger to the mains.... (i am not expert/engineer as you may imagine, but not afraid to grease me fingers:) )
I do not know how a battery charger functions internally. So I would not use it as a measuring tool. But maybe others have heard of this?
Nothing is as useful as a multimeter for trouble-shooting electrical circuits. I could not live without one and I am not an electrical engineer. Even the very cheap ones provide so much useful information.
Current Vehicles
2003 Toyota Camry
2003 Toy 4Runner
2003 Toyota Camry
2003 Toy 4Runner
Forget the gauge on your battery charger. In my experience seldom do they actually work properly, and you it may be an ammeter and not a volt meter. A multimeter is great if you know how to use it (ie: set range, configure test leads, ect.) but buy a test light for basic troubleshooting- the bulb draws an amp or two and will better show you a voltage drop across a bad connection, whereas a meter can still read battery voltage if so much as one strand of a wire is intact, because it draws so little current. You can keep it in the car and wont regret the purchase.
