1996 850R Broken rear sway bar. Remove or repair?
Marcobrick
Year and Model: 2003 V70T5
Has thanked: 3 times
Post by Marcobrick »
It turns out the funny noise I have been hearing on sharp bumps is my rear sway bar. The left side mounting is broken clean off. It appears to have been welded previously. The surprising thing is, the car does not handle like a warm custard despite the rear sway bar having no function. Is there anything wrong with just tossing it? A replacement in this part of the world may be tough to source. It actually handles very well indeed though brand new shocks, struts and mounts all round definitely helps. Opinions?
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Not until you do a fast corner
You should have a lot more understeer (plowing)
Has thanked: 311 times
Been thanked: 818 times
Many 850's, like about half of them, left the factory without a rear sway bar. I've driven a few cars before and then after a rear sway install and you can certainly tell the difference but it is not earth shattering. The car will be just fine without it, but if you were to replace it the difference would probably be satisfying.
In your shoes I would keep an eye out for an 850/x70 at the junkyard, you can pick up a rear bar that way. You may not get an R sway bar (they are the thicker of several diameters Volvo used) but that would be splitting hairs, as you have observed. In the meantime, continue to enjoy the car.
Marcobrick
JRL wrote:Not until you do a fast corner
I live on a mountain and my route to work is a reasonably entertaining stretch of road. I am an enthusiastic driver and I can categorically state that the car does not understeer badly, a little more than my Alfa Romeo 155 did but those things are on another planet in the handling department.
I will look out for a junkyard replacement but these cars are very uncommon where I live.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Ben850
Been thanked: 7 times
Post by Ben850 »
It looks like it is uphill both ways by the looks of your signature photo. Nice though.
I do not believe my '93 actually has a rear torsion bar. I also think I have felt the understeer dive while hitting some of the nice contours here in my area.
I am fortunate to have found a seemingly new rear suspension from a '98 s70 which will also help with a five lug hub conversion in a single fell swoop.
I have not installed it yet. Next spring.
Of course it is spring for you. Have fun.
There is fresh paint on the torsion bar under a little mud. I was lucky at $$67.50 or so USD.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Marcobrick
My signature photo is a bit out of date!
This is my back yard now. :D
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Ben850
Post by Ben850 »
Beautiful. I must take a drive down there.
Wait...
This bridge is connecting the Peninsulas of Michigan USA. I do this one a few times a year.
Might be expensive to freight my little fleet to N.Z.
I have actually never been south of the equator.
Hmm.
Thanks. I mean that for real. Added to the proverbial bucket list.
Mackinaw Bridge Michigan
Marcobrick
I removed the broken sway bar for now. It drives just fine so I can bide my time until I can find a new (used) one.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
