Volvo 850 Turbo Rebuild Kit Options
Baptiste1106
Year and Model: 850 1994
Post by Baptiste1106 »
I believe my turbo needs a rebuild. Based on these photos, what do you think ? Where should i get the rebuild kit from ebay, ard tuning or kinugawa ?
Oil on PTC
Oil on PTC
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
When was the last time your PCV system have been serviced?
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 292 times
Been thanked: 765 times
If you wonder about the condition of the turbo, then pull the fresh air snorkel, reach in and check the turbine for shaft play. Check for in and out play, and side to side play. I am not sure the oil residue really tells you anything about the turbo.
For the record the turbos on these cars are very hardy, they can run a long time, but check it out.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Bad oil seals on the turbo itself will cause the car to smoke badly but it won't cause the turbo itself to get oily.
If you do decide to rebuild it buy the Mitsubishi kit or maybe the ARD kit. Many of the eBay kits are pretty bad but eBay is OK so long as it is indeed a Mitsubishi kit and not just listed with the Mitsubishi number - read the listing carefully.
I don't know anything about the ARD kit but I can't imagine them sending out junk.
Baptiste1106
@ Ozark Lee... My car isn't smoking but I smell oil thru my cabin and the identical smell out the exhaust. I showed these same photos to my Volvo mechanic and he said its def the turbo seals. I also pulled the fresh air snorkel and there was a puddle of oil in the snorkel
Been thanked: 471 times
Post by cn90 »
I have a question for the Turbo gurus...
The background:
- My 1998 S70 GLT with 165K miles drinks 1qt/1,000 miles.
- My 2005 XC90 2.5T with 85K miles drinks 1qt/1,500 miles.
From my reading of this topic:
1. When do you expect the Turbo to be rebuilt?
2. According to this Volvo tech, they see the turbo seals failure at 110K+, is this true?
http://www.justanswer.com/volvo/8p3iy-o ... miles.html
Volvo Tech wrote:...It's fairly common around your mileage 110k-130k to see the turbo fail.
At a dealer it will be close to 2 grand to replace. The part is 1100 bucks plus 7.3 hours labor.
tryingbe
Post by tryingbe »
cn90 wrote:I have a question for the Turbo gurus...
The background:
Are both car's PCV system serviced lately?
85 GLH, 367 whp
00 Insight, 72 mpg
Post by cn90 »
Yes,
Both cars had the PCV system overhauled 1yr ago.
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
So, 8 years later the options for 15G rebuild kits are probably worse than ever.
ARD is not active anymore, so where could I get a quality rebuild kit or a rebuilt 15G or a known working 15G?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1503 times
Been thanked: 3817 times
I think I have one in my stash
