1991 940 SE - where's the fuel pump relay?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Neal Bell
Year and Model:
Post by Neal Bell »
It's not behind the ashtray! The fuses on this car are at the end of the dash on the driver's side. Apparently the 1991 940 SE is a little "different"...
Neal Bell
Year and Model:
Post by Neal Bell »
The relay board is up on edge inside the console, facing out toward the right-side footwell. You have to drop the big plastic doodad from under the dash on the right side to get to it. The relays are packed so close together on the board you can hardly work them loose. The fuel pump relay is green on mine, top row, second from the left.
