1991 940 SE - where's the fuel pump relay?
It's not behind the ashtray! The fuses on this car are at the end of the dash on the driver's side. Apparently the 1991 940 SE is a little "different"...
The relay board is up on edge inside the console, facing out toward the right-side footwell. You have to drop the big plastic doodad from under the dash on the right side to get to it. The relays are packed so close together on the board you can hardly work them loose. The fuel pump relay is green on mine, top row, second from the left.
- 4404 Views
Last post by wizechatmgr
- 11 Replies
- 2059 Views
