1998 S70 Lower transmission line leaking after seal R&R
darrinm503
Year and Model: 2005 V70R
Post by darrinm503 »
My daughters 1998 S70 had a leak on the lower transmission line coming off the radiator. I replaced the seals with IPDs transmission line kit but the leak persists and it leaks at a greater rate. Should I replace the hose, the radiator, or both? Could I plug the ports for the transmission cooler and just delete it?
2005 V70R
2000 C70 HPT Convertible
1998 V70 T5
1998 S70 Base
Been thanked: 467 times
Post by cn90 »
Try this...
DIY: 1998 S70 GLT Trans Cooler Line Rebuild for $10!
https://www.matthewsvolvosite.com/forums ... hp?t=55794
BTW, use the O-rings from dealer only.
