2001 S60 Rapid Battery Drain
chv3ch
Year and Model: S60 2.4T 2001
Has thanked: 3 times
Post by chv3ch »
Hi everyone,
I've read through many posts concerning electrical problems for the S60, but have not found a similar problem with resolution. I have a "significant" short somewhere, but have not been able to locate it.
The battery drops 1V every ~15 minutes.
First I checked every fuse to see which ones had voltage. I then pulled those fuses and measured the current across the pins. The highest current I found was 240 mA on position 27 of interior bank of fuses. This is the "Front Door Module". I also found 59 mA on position 23 "Light Switch/Climate Control Module, OBD, Steering wheel module".
I would not expect either of these to kill my battery so quickly.
I have attached a matrix of current draw on each fuse (have not quite finished it yet, will update it later).
Anyone have suggestions where else to look? I figured I should smell the problem by now :shock:
chv3ch
Post by chv3ch »
oops forgot the attachment
Electrical.xlsx
(1.26 MiB) Downloaded 480 times
draser
Year and Model: 2005 S60 2.5T
Post by draser »
Do all car electrical systems work? What's the voltage across battery with engine running?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
CountryBum-kin
Year and Model: S60 2002
Post by CountryBum-kin »
Check and test battery,star motor,and alternator for faults.
chv3ch
Post by chv3ch »
I have taken the battery into local parts stores and checked twice - both times it was OK.
Also have checked the alternator twice at 2 part stores.
If I disconnect the battery while the car sits - no problem, it will start every time. Leave it connected for more than 10 minutes and it will not longer start.
No other problems with electrical system.
Today I will remove fuse #27 and see if the battery drains....
chv3ch
Post by chv3ch »
Oh yeah - voltage across battery while engine running is 13.6 volts every time I check it. Seems normal
Has thanked: 1502 times
Been thanked: 3817 times
Pull the 23 and 27 fuse and see if that at least stops the drain.
That voltage drop is so severe, I think the problem is somewhere else.
a 300 mA current draw is about 6x too high, but that will take about 250 hours to bring a Group 24 battery to 1/2 charge.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Window switches are known culprits. When the battery is low do you hear any clicking noises?
chv3ch
Post by chv3ch »
With the 23 and 27 fuse removed, the voltage drop is about 0.1 volts per 15 minutes. The voltage was at 12.5 volts with everything connected and ignition off. and 30 minutes later the battery voltage reads 13.3 volts on the battery terminals. "Big improvement", but the car will not start now. Still seems to have a large current draw somewhere. With the 27 fuse removed the front door locks, power windows, and temperature gauge does not work.
coflynn
Year and Model: 2002 S60 AWD
Been thanked: 6 times
Post by coflynn »
A few notes:
1) How old is your battery? Those in-store tests aren't reliable - I had a battery that I was told was "better than new" and was only ~3 years old, but my car kept dieing, sometimes in the span of less than an hour while parked at a store. Replaced battery and issue was 100% fixed, and I confirmed there was no unexpected power draw that a new battery just masked.
2) You should measure the current at the battery - some of the lines don't go through the main fuse box (notably the alternator) so there could be a draw there. See https://www.matthewsvolvosite.com/forums ... =9&t=51058 .
