1996, 850 Turbo, Doors Locks
I started the car this morning and stepped out of the car to clear some ice...the door had shut behind me and I was locked out of the car. Not sure how it happened, but I thought there were things in place to prevent this? Luckily I had a spare set in the house.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
- Has thanked: 2197 times
- Been thanked: 1851 times
I didn't think the door could be locked either. If I remember for an 850 you either had to push the button down and hold the outer handle out, or you had to use a fob or key. Sounds like there may be wear or a problem with the lock mechanism.
Neil
Neil
- phils94850
- Year and Model: 2009 s60 turbo
I had one that would do that. I found the problem there was a short in the wiring somewhere in the loom where it goes to the drivers side door. I never could find it to fix, I just knew it would do it sometime. I could jiggle those wires and the door would lock so I knew it was somewhere in there.
1996 Platinum Edition
- 929 Views
Last post by beigg
- 453 Views
Last post by wisewoman
- 395 Views
- 1568 Views
Last post by DurangoStang
- 381 Views
Last post by misha
