2000 v70xc bevel gear replacement/rebuild
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
I am having issues with a bevel gear in the 2000 v70xc, can I swap with one from a 98? Or are they easy to rebuild? bearings, etc.? Thanks
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
jimmy57
- Been thanked: 320 times
The flange where rear driveshaft attaches is different but can be swapped from yours.
They are not hard to rebuild but you need a tool to unscrew the RH carrier bearing cap/seal holder. You also need an inch pound torque wrench for the pinion bearing preload check.
Is there anymore info on rebuilding the bevel gears. I have a 2000 v70 xc also?
I'm trying to locate the pinion bearings. I'm reading the numbers on the bearings, but no luck yet in finding them. Seems like others have run into the same roadblock.
