1999 S70 Did I just get ripped off?
Has thanked: 1850 times
Been thanked: 1710 times
Re: 1999 S70 Did I just get ripped off?
I don't think so. Is the price high for a 99? To me it depends on maintenance and how the car has been looked after.
If there is some for of maintenance history then you can feel better that the car has been 'babied'.
Recently a 1997 850 with about the same mileage went up for sale here in Calgary, and it was priced at over $7000. It sold in days. A 2000 V70R with 190kkm went on for $7500 and sold almost straight away. Having said that, I met someone who bought a 2000 R similar to mine with only 120kkm on it and spent over $6500 almost straight away. Car hadn't been serviced (body was in great shape), but the 5 speed auto (known problem area) failed, along with various other age related stuff (vacuum pipes).
For that money, there are lots of newer Volvos on sale over here at around that price, but they have over 200kkm on them.
So if you have a good car, can find where it was serviced or have a recent service history then I think it is a good buy. No AWD to go wrong or Turbo issues. As stated earlier buy others, check the timing belt has been done recently and the serpentine belt, then I would consider a Stage 0 service then you know where you are on maintenance.
Good luck with your new car!
Has thanked: 292 times
Been thanked: 765 times
For that price you may have overpaid a smidge or you may have executed a very fair deal or come out ahead on it. I agree with scot850, check it out, make sure it is up to maintenance, and enjoy it.
northernlights wrote:... There are so many types of coolant out there that using the OEM spec (Glysantin G48 on the 850's!) seems wise unless one has unusual experience with coolant, like working for BASF or writing a thesis. ...
... :lol: thanks for the humor (oh, and no disrespect at all intended for the comment)!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
You made a fine deal. Give yourself a pat on the back.
I will replace all fluids, filters and common seals ASAP.
Focus on achieving Stage 0.
It can take you to places for another 200,000 miles.
northernlights
Year and Model: 850 Turbo 1994
Location: Florida and/or Raleigh NC, depending on the day
Been thanked: 8 times
Post by northernlights »
erikv11 wrote:For that price you may have overpaid a smidge or you may have executed a very fair deal or come out ahead on it. I agree with scot850, check it out, make sure it is up to maintenance, and enjoy it.
I'm trying to spread good karma to combat the evils of DexCool!
jonk1086
Year and Model: 1999 S70
Post by jonk1086 »
xHeart wrote:You made a fine deal. Give yourself a pat on the back.
What does Stage 0 mean?
jonk1086
Post by jonk1086 »
850 LPT wrote:Congrats on your purchase, what a find.
As mentioned above, if the timing belt has never been replaced, put that on top of your list.
Is there a way to check the timing belt easily, or will I have to take it to my mechanic? By the way, I have an awesome mechanic who used to own a Volvo, so I have some great support with him.
Blockpartie
Year and Model: ...
Post by Blockpartie »
You could measure how much slack the timing belt has. That would give some indication wether or not it is in good shape. Visually you can only check so much which still is not good enough.
At the end of the day just replace the t-belt, tensioner and rollers. Spending some money versus "loosing" all your money because the engine eats itself should make this an easy decision.
xHeart
Post by xHeart »
It is listed under Quick Nav drop-down menu, here is your quick access https://www.matthewsvolvosite.com/what-is-stage-0.html
