2006 V70 Transmission fluid drain and fill with vacuum extra
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
BMW's long drain intervals seemed to coincide with them paying for maintenance through 50K miles and even longer on many of the CPO used cars. I'm so sure those events are totally unrelated........
The combustion residue carried in oil HAS TO GET OUT or the rubber seals suffer. There may be new materials used that do tolerate the residue but those were not in the engines first getting these long drain intervals as they all are pouring oil at multiple places.
The trans case side fill on BMW's makes the drain n fill a messy and complicated process.
I wonder if Fumoto makes a valve to replace that fill plug?
jh_on_the_cape
Year and Model: 2006 V70 n/a FWD
Post by jh_on_the_cape »
Just an update. I had the car pointing slightly downhill and the vacuum extractor pulled out exactly 4 quarts of ATF. I replaced it with Valvoline Maxlife ATF ($$ at almost $8/qt) which is listed as Toyota T-IV using a funnel with a tube that fit nicely into the dipstick hole.
The car shifts noticeable smoother now. I will recheck the fluid level later and top off if necessary.
Thank you very much for the responses. Even the guy at NAPA said he does the same thing every 3rd oil change on his truck.
Bright Red 1994 850 Wagon, nonturbo, FWD, stickshift 150k-ish miles SOLD
2006 v70 FWD nonturbo, boring silver A/T, 200k miles
jimmy57
Post by jimmy57 »
I bought Valvoline MaxLife synthetic with T-IV listed for $4.27 at Wal-Mart here yesterday.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
I was changing oil today and decided also to drain transmission and refill with Valvoline. Just refill, no adaptation, since I'm lazy. For last two ATF changes I used Idemitsu Type-TLS and it worked better than Mobil 3309 (in both my P2s), so why not to drop ATF thickness further I've asked myself?
There's some positive difference, the shifts are a bit smoother, especially in slow down sequence. On the other hand, transmission shifts not that bad in winter, need to wait for stop and go in summer, when it really makes crazy :)
So far 1 gallon bottle is very convenient, this is exactly how much old fluid drained. Will probably do drain and fill every oil change (7500 miles).
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I also put a gallon of Valvoline, the rest being recent Toyota IV stuff. I even think it was a bit overfilled, the level was a bit above the hot max line with the transmission warmed up.
It worked well during fall days, but now in very cold (Canadian) mornings approaching 0F, I've experienced a strange behavior. For the first 2-3 minutes after a cold start, the car would not move (transmission in D and engine revving up). Probably there was not enough fluid inside the torque converter, which makes me think that the Valvoline stuff contracts its volume much more than the Type IV or Mobil 3039 oils. Other than that, I also felt the Valvoline helped the 2-3 up-shifting be more smooth
vtl
Post by vtl »
Do you warm it up? Let engine drop to idle revs, then step on brake, put transmission in D and keep it for a few minutes.
I think it's not a ATF volume, it's rather a sticky solenoid or other kind of line pressure problem.
Been thanked: 4065 times
jimmy57 wrote:BMW's long drain intervals seemed to coincide with them paying for maintenance through 50K miles and even longer on many of the CPO used cars. I'm so sure those events are totally unrelated........
I know you were all on the edge of your seats but I pulled off two drain amd fills on the B!W slusher earlier this year. This car had been specifically designed to make it impossible for the DIY to service. I had to rig an IV bag of ATF to fill it slowly while idling as it won't take fluid quickly.
Shifts have been much smoother since. I sneer at the BMW dealer on the way to work.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I've avoided the Gibson Method on my cars because there's no good place to add the cocktail onions to the transmission. :D
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
oragex
Post by oragex »
vtl wrote: 22 Feb 2015, 09:02 Do you warm it up? Let engine drop to idle revs, then step on brake, put transmission in D and keep it for a few minutes.
This is a low overdue reply :)
It was not about warming up the engine, simply the Valvoline stuff has such a characteristic that the volume of fluid was really changing with it's temperature. All transmission fluids have a volume change with temperature, but Valvoline was way off the mark. When it was cold in winter mornings, the volume was so low the torque converter would simply not move.
I've since replace it with the Toyota Type IV and the issue went away.
E Showell wrote: 30 Nov 2018, 20:43 I've avoided the Gibson Method on my cars because there's no good place to add the cocktail onions to the transmission. :D
The monkeys will eat the onions , anyway, or do you play your guitar waiting with the GIBSON method?
