If it skipped enough to stall, it would damage the head.clifford06 wrote:If TB skipped, am I looking at a head job due to possible bent valves ?
2000 S70 T5 Stalled on freeway
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Re: 2000 S70 T5 Stalled on freeway
Redneck
- Year and Model: Volvo 854 1996 GLT
- Has thanked: 10 times
This is exactly why I always buy OEM parts. Independent mechanics will install the cheapest aftermarket parts they can buy because this will increase their profit from the repair and make the customer happy because he didn't have to pay much for the repair. If you go to Indy mechanic, at least buy OEM parts and make sure that he doesn't steal them for himself and put in aftermarket ones instead, or sometimes does not replace them at all (you may never know it). The ideal would be to stand there and watch him do the work. Never install aftermarket parts into your Volvo (with a few exceptions for few non-critical components). It is a waste of time and money. Even some of the OEM parts are not as good as the original ones from the factory.
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Greetings. Checked car today. Oil is due for change, but not milky. Removed TB cover, and belt is loose. Water pump locked up. Damn Damn Damn. Okay , am I looking at a valve job ? Thoughts and opinions respected.
- Year and Model: Lots
- Been thanked: 128 times
You need to check timing marks. Get a new pump (Aisin WPV-800) and a new belt, OEM INA tensioner and INA OEM pulley as they have been under stress.
Refit them all and time the engine. Then do a compression test. If numbers are low or hardly even there you know the head must come off for bent valves.
clifford06
Greetings. I'll install water pump and pulleys this weekend and re time the engine and compression check. If numbers are bad , this maybe the end of my Swedish experience.
- rspi
Contact rspi..
I would not waste my time with installing any parts if I were you. Also, you car likely has CVVT stuff and will require special tools, equipment and skills to time that motor correctly. Pull the head or cut bait.
- rspi
Contact rspi..
A water pump failure with 16,000 miles on it. That company should pay for a motor rebuild.clifford06 wrote:Car has 142k miles. Replaced TB, water pump at 126k, 3k after purchase.
No special tools required to time a CVVT motor, even if it's dual CVVT. Just set the pre-load which you can find plenty of threads here about.
If you rebuild the engine you'll need a new timing set anyhow. If you buy a used engine you'll want to transfer & fit the timing set there.
If you plan on getting rid of the vehicle that's an entirely different story.
- Has thanked: 1504 times
- Been thanked: 3817 times
Crap on rye bread....
- 798 Views
Last post by E Showell
- 1051 Views
Last post by leonardthefast
