94 850 Turbo starts fine but dies when driving
arlo1870
Year and Model: 850 turbo wagon 1994
Post by arlo1870 »
Love my 94 850 Turbo Wagon but it does have it little issues like fan cutting out on heat/AC after a couple of minutes, and rear door not always locking. Then last week it starts dying on me, I haven't had any real mechanical problems with it since purchased (6/2010). Finally I get it home and park it, luckily I was about 1/4 mile from home when this started. Each time it dies I have to set a few minutes before it will restart, then when I try accelerating or slowing down it dies again. The next day starts fine but dies while I am pulling into my alley and backing up to change direction of travel. Then I get a couple hundred ft. and dies again. At this point turned around get home and park it. I would greatly appreciate any useful input.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
There are many possible causes of stalling. One of the most common is a failing fuel pump relay, but this is just a guess. To check it, I would recommend following the instructions in this classic fuel pump relay thread:
https://www.matthewsvolvosite.com/forums ... php?t=9681
There is a good general list of possibilities for the causes of stalling here. It might give some ideas for things to check:
https://www.matthewsvolvosite.com/forums ... 5917#65917
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Unplug the mass airflow sensor and see if it will stay running on its own.
'98 S70 T5
2016 Chevy Cruze Premier
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Any codes or CEL?
Has thanked: 311 times
Been thanked: 817 times
Mass air flow (MAF) sensor is the first thing to check. Unplug it before you start up the car, then drive it around. If it no longer dies, that was your problem. Post up your results people can advise you on getting a replacement.
If it is not the MAF then I would probably look next at the fuel pump relay.
arlo1870
Post by arlo1870 »
I unplugged MAS once I found where it was located and it made no difference. Tried to drive and again keep dying when I when to stop or slow down to turn.
I purchased a OBDII & CAN SCAN TOOL. Then found it is missing the cable to connect to PC.
I ran a scan following directions I saw on a Robert DYI video.
Codes were POOO! Fuel volume circuit open.
PO331 Knock sensor-2 circuit range performance
PO326 Knock sensor-1 Blank
Also under DTC Guide Open or short in Park Neutral position switch circuit Poor Park
Neutral position switch circuit connection, Misadjusted park, Faulty Park neutral switch position.
Thanks for your original suggestions. I am going to go try pulling Fuel relay and running the wire between the two slots to test as suggested on one of the videos I watched on line.
Would appreciate any additional recommendations.
