1995 850 Ignition/Flashing Arrow (New)
Has thanked: 311 times
Been thanked: 817 times
It's still a good idea since the trans fluid is so muddy.
I don't know which method is recommended in the video but you should do a series of drain and fills, where you let out 4 quarts, put 4 back in, drive for a few hundred miles, then do it again. You're going to want to do at least 4 changes like that to clean up the fluid and get rid of the Lucas in there.
jtmarks923
Year and Model: 850 GLT 1995
Post by jtmarks923 »
Hi all, so here's my update:
I changed the ignition switch and have flushed the tranny, but my speedo problem is still happening, followed by the flashing arrow. I will try and be more specific in my symptoms:
1. When I turn the key, i don't have to turn it back anymore, that problem is fixed
2. The same problems with speedo and light are at it again
3. Could this be my VSS or RPM sensor? The RPMS do tend to get jarry when the speedo starts acting up, sometimes before the arrow comes on. Is this electronic?
4. I know it can't be ignition switch itself now. Got a new one, same symptoms, had it replaced with another one from the parts store, same symptoms.
5. Is this the ABS module? When I turn the ignition and the ABS and TRACS light do go off after about 2 seconds, but in that two second window, the ABS light blinks rapidly twice. If your not watching closely you'll miss it
Thanks yall
jtmarks923
Here are codes I recieved
A1
232
322
A2
436
232
231
A3
424
142
A7
113
122
B1
412
414
417
222
B2
122
B5
213
233
B
jtmarks923
Anyone?
