1999 S70 Removing ECU Box to service expansion valve
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
It appears to service the expansion valve (and perhaps replace the idler while there) I need to remove the ECU box. Are there any specific steps. This is one thing I don't want to mess up!
- Has thanked: 1614 times
- Been thanked: 4078 times
Just pull the accordion hose, undo snaps, remove lid, then wiggle the " sidewalls" up. Clear the rear feed hose from the climate unit (attaches to firewall) as you lift.
Leave the ECU and TCU ( if applicable) in place.
That will give you enough space to service the orfice and lines
- 818 Views
Last post by marron4655
- 610 Views
Last post by MistyB
- 2219 Views
- 757 Views
Last post by drbruno4
- 2937 Views
Last post by Paulv
