1999 S70 T5 - Markings on oil pump gears?
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Why do the gears inside the oil pump have markings on them? Gears are symmetric so it shouldn't matter how the small gear sits in the bigger one?? Does anyone have deeper knowledge about this, I would really like to know.
BMW 540i 2002
S70 Base 2000
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Why did you remove it?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
What is wrong with your oil pump?Why did you removed it from the engine?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1506 times
- Been thanked: 3820 times
Perhaps it is marking inside and outside faces of the gears ??
- kallekula
Front crank seal was leaking so I replaced seal, pump gasket and pump o-ring. Opened up the pump because I wanted to see if there was oil sludge in there but it was pretty clean.misha wrote:Why did you remove it?
BMW 540i 2002
S70 Base 2000
- 1956 Views
Last post by Wichitas80
- 2267 Views
Last post by truenorth
