98 V70 ATP-AT-205 Oil Additive Question
- Has thanked: 311 times
- Been thanked: 817 times
Wait, there are errors on the internet ???
You've been speeding on that other site, haven't you......
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I'm not crazy about genies in a can, but I have used this product on my previous car when all else failed and it worked! I believe it is the same premis, restores rubber doesn't plug holes.
http://store.gobluedevil.com/oil-stop-leak-49499/
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
98v70dad
- Year and Model: 98 V70
I'm not crazy about them either. Thanks for your comments. I've used seafoam from time to time and nothing else, EVER.mecheng wrote:I'm not crazy about genies in a can, but I have used this product on my previous car when all else failed and it worked! I believe it is the same premis, restores rubber doesn't plug holes.
I don't have bad leak, just a little valve stem seal leakage I think. I'm leaning towards putting in a bottle for a few weeks and then changing the oil. I tried changing to "older car" oil and it helped a little, but didn't make a big difference.
I think AT-205 is a solvent and while it may help renew the seals it may also reek havoc with the aluminum block and other aluminum parts so I would want it in the system only for a short time.
Someone said the minimum time was listed on the bottle, but that's not so. I took a look the other night and there is no information about how long it takes to work. I think they just recently changed the label.
JDS60R
- Been thanked: 3 times
New box (not bottle ) says - "If leaks persist after 5 hours consult a professional".
I called them - same product - new bottle and label. They simplified the label so it was more customer friendly. Only thing that takes close to five hours is a rear main seal - per them.
Retired
- 1337 Views
Last post by erikv11
- 44 Replies
- 13598 Views
Last post by Matty Moo
- 1015 Views
Last post by sleddriver
- 17570 Views
Last post by Oly850
- 9 Replies
- 3093 Views
