I generally don't believe in adding stuff to my cars fluids as a fix, but I've researched ATP-AT-205 and I have read many positive comments about this stuff on this website and others. What I've read from many sources is that this plasticizer has an amazing effect on small oil leaks. I have some small leaks and think this might be a good preventative solution. I don't think it will do any damage other than the 10 buck hit to my wallet if it doesn't help.
So, I am planning on adding a bottle to my oil. The instructions say that it treats 6 quarts, but it doesn't say how long to leave it in. I can put it in a week before an oil change or put it in with an oil change and it will be in the system for about two months. I'm inclined to put it in before the change so I can control the exposure time.
I know others on this website have used it and my question is did you put it in right before or right after an oil change? Also, if you used it and wish you hadn't I would like to know about that also.
98 V70 ATP-AT-205 Oil Additive Question
This thread and pic might change your mind about this crap
https://www.matthewsvolvosite.com/forums ... =1&t=69832
I would find the oil leaks and fix them with gaskets, o-rings, or washers
on edit - link was for sealer, not additive as proposed. Carry on and keep Volvos alive!!
I have added a bottle at oil change (and left it in until next oil change). In my experience, its a good idea and works well for those odd leaks you cant track down. I try to use the "thin" additive instead of the "thick gooey" one. I have had some degree of oil leaks on all 3 of my cars. 2 of them needed cam seals replaced and clogged PCV so def. look into those too.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
ATP-AT-205 is not a sealer its a plasticizer that claims to return plasticity to old seals. I would not use a sealer either. Also, I didn't mention it but my car is a non-turbo.abscate wrote:This thread and pic might change your mind about this crap
98v70dad
I've already replace the cam seals and have done the PCV modification. I believe I have valve seal leaks. I could live with them but I don't want to if this will help remediate them.mika wrote:I have added a bottle at oil change (and left it in until next oil change). In my experience, its a good idea and works well for those odd leaks you cant track down. I try to use the "thin" additive instead of the "thick gooey" one. I have had some degree of oil leaks on all 3 of my cars. 2 of them needed cam seals replaced and clogged PCV so def. look into those too.
JDS60R
- Been thanked: 3 times
ATP AT-205 is fine.
You can leave it in the entire time. Some seals take several hours (of run time) to seal up . If the seal has a break in it you should replace rather than try a sealant.
Retired
- Has thanked: 311 times
- Been thanked: 817 times
I have added it, right after an oil change. This one and Auto-Rx are the only voodoo-in-a-can I have ever used.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
On the product it says it takes XXX hours or miles to work. I don't remember off-hand what it was. After PCV and cam seals, it helped my car with symptoms of slight RMS leak and valve seals. I don't want to burn valves, I can't live with leaky stem seals.
Steve, I think the other thread OP indicated that was a form-a-gasket product used instead of a seal, not an additive. Someone tried to patch a pinhole in the line with it I thought it said?
Current Volvos:
Yes, the link with the gunked up picture for that turbo line was a seal former, not an additive.
'97 855 N/A
'97 855 N/A
thanks guys, Fixed post with edit.
Whew - well on the path to an error-free internet.
- 1334 Views
Last post by erikv11
- 44 Replies
- 13572 Views
Last post by Matty Moo
- 1015 Views
Last post by sleddriver
- 17546 Views
Last post by Oly850
- 3085 Views
