sun roof
volvomat
Year and Model: xc70 2003
sun roof
Post by volvomat »
on my xc70 2003, I try to open the sun roof and there is no response, the fuse is ok. What can I do?
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Do you have "alarm system service required"?
volvomat
Post by volvomat »
Yes,I have alarm service required.
vtl
Post by vtl »
Alarm siren and sun roof sit on the same smallish computer bus. When one dies, another fails to communicate.
http://www.volvoxc.com/forums/showthrea ... went-south
volvomat
Post by volvomat »
Few months ago, I remove the siren fuse, because it was ringing often for nothing.
vtl
Post by vtl »
It failed just like many others.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I run without the siren module, but I did not remove it's fuse. All electrics work properly. It's not easy to remove the module, but still doable
vtl
Post by vtl »
Much easier through the other side (remove bumper and passenger side headlight).
volvomat
Post by volvomat »
I replaced the 5 amps fuse for siren and the sun roof works perfectly. Thank you vtl, Now I have to repair the siren system. On You Tube on Oct. 14 2014, there is a video: Volvo alarm system service required cheap fix V70 S60 made by Sirobb. Do you have something to say about it? Or can I buy a rebuilt?
vtl
Post by vtl »
Yeah, about right. There's easier route to get to siren, without drilling out damn rivets and struggling with secret bolt (through the headlight). I used cheap metal saw to cut the plastic box, it looks way more accurate than Sirobb had. Battery was $12-something, under $13. You need to know how to do simple electronics fix, i.e. cleaning the board, determining damaged parts, restoring missing traces, soldering a new battery.
I'm not sure you can buy a rebuild. Who rebuilds them? Buying a used part is senseless, because it is already failed or will fail soon.
