2002 XC70 Left Drive Shaft
flyingswede
Year and Model: V70AWD 1998
Post by flyingswede »
I got a little heavy handed checking bolt on drive shaft. Sheared the bolt. Has any one had any success with an easy out :oops:
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Can you pull it out as is? If so then just take a vice grip to it once it is out. You may need to loosen and/or remove a few other components and do some up down lifting of hub to get it out with the added length.
Otherwise I see no reason an easy out would not work. Thinking about it, depending on how deep it broke it is a pretty safe drill. The bolt should not be to tight and should come out easy.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
A left-hand drill bit might be a good idea:
http://www.harborfreight.com/left-hand- ... 61686.html
