If your ETS light is on you have to deal with that first. Its a matching ETB, Xmodex, or rebuilding it - choose your poison.
Theres no magical workaround once the ETB goes kaput.
1999 c70 Running issue engine stumbles
- Has thanked: 1505 times
- Been thanked: 3817 times
Re: 1999 c70 Running issue engine stumbles
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
The issue is that open injector again, like prev. mentioned. Sounds like you get a lot of fuel in that cyl., which is not good. Knowing that ecu provides ground for injectors to work, I'd venture that your issue is injector harness touching chassis somewhere, hence open injectors. I'd start at injectors plugs and follow harness all the way to ecu, or use an ohm meter and unplug inj 2 and test either contact of connector to chassis.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
abscate wrote:If your ETS light is on you have to deal with that first. Its a matching ETB, Xmodex, or rebuilding it - choose your poison.
Well it has been replaced with a Xmodex one..I'm going to try the ECU connector today and see if it is nasty..Like someone said back in the thread,it's worth a try..I just don't get it that shutting the thing off taking the key out and then restarting it sometimes has an effect and it will straighten out until it acts up again...But thank you for your post...At least I know I'm still being seen.lol
A loose ground will wreck havoc. There has to be a list of the locations somewhere here
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
