high idle solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
A.Baker
Year and Model:
high idle solved
Post by A.Baker »
I found that the high idle was caused by the idle speed motor opening and closeing. The other problem was that the car was getting harder to start after a few min.s of runing. WELL there is a sensor for the ECM under the intake between #4 and 5.It controls the temp reading for the ECM that controles the idle speed motor. The part was 40.00$ from the dealer w/a copper seal (must have) and problem is solved. Now on to the turbo rebuild. :D
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Excellent. Thanks for the update Mr. Baker.
Also -> Amazon link
Guest
Post by Guest »
interesting. i cleaned out my idler motor, and the problem hasn't come back yet. i guess i might as well have a look a the sensor anyways just for the hell of it. where exactly is it? right underneath the intake?
ozzimark
Year and Model:
Post by ozzimark »
oops, i guess i logged out some time ago... but to clarify my question of where it is, is the sensor actually in the intake, or is it attached to the engine block somewhere?
