My 150K mile Volvo picked up a stumble recently and after reading the code I was lead to a Cylinder #5 misfire.
During my investigation I found the #5 spark plug well had a fair amount of oil in it which I'm guessing shorted out the wire to plug connection.
Since the other plug wells looked clean and I didn't see any obvious oil build up on the top of the cam cover near #5 I assumed that I had a leak between the Cam cover and the head.
Now that I have the cam cover off I've found a couple interesting things.
1) I see four small holes surrounding each cylinder, some of these had some gunk in them which I tried to pick out. Prodding around with a toothpick these holes aren't very deep, just a few mm. I can't tell if they are clogged or if there is a sharp angle to the passage. Are they supposed to supply oil? If so what's the best way to clean them?
2) I notice there is a lot more oil tarnish on the Cylinder #5 side of the head. Is this normal for these engines, or do I have a coolant problem?
Picture below. I have a toothpick standing in one of the holes referenced in my first issue.
2000 V70 GLT - Oil passages in head and Cyl#5 overheating?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I'm pretty sure those ports lead to the lifters, they do in the pre '99 heads.
Not sure why there is more tarnish near #5. I have several photos & videos of heads open that you can look at to compare.
Why did you pull the cam cover? Was oil on top of the spark plug and on the wire?
- Has thanked: 1613 times
- Been thanked: 4078 times
You should do a compression test to see if you have a gasket problem. You'll need to put it together first, of course. Do cam seals while you have it apart. Did you test the ignition coil my moving cylinder 5 to cylinder 1 to see if that was misfiring? That could be the whole trouble.
- 1788 Views
Last post by Livens
- 1738 Views
Last post by petermetzger
- 1666 Views
Last post by AD_NAPCO
- 20 Replies
- 3402 Views
Last post by NYCKID221
- 1408 Views
Last post by rebecca8
