Thanks for trying. The bottom pin has a plastic part sticking out at 90 degrees and that keeps it from coming out clean. My floor mat covers the foot rest, so until I order something, it will remain as is.
Shane
99 V70 Removal of 'dead foot rest" part 9132550
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Did you noticed how bad the area to the left of the rest was? It was all messed up. Well I used what I had to add a little patch. Thought about replacing the entire area, but that rubber bottom goes under the steering wheel.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
It looks like it comes DOWN then back. I would have sworn I pushed my 1999 up and then back.
obayha
It comes down,then back,then breaks.abscate wrote:It looks like it comes DOWN then back. I would have sworn I pushed my 1999 up and then back.
The new standard procedure for removal.
I would like to know if anyone has removed one without breaking.
Shane
1998 V70 T5 331,000
And the broken piece falls into the bowels of the car so it can't be JB welded back.
- v-45magna
- Year and Model: 99 S70 GLT
- Has thanked: 2 times
I thought that, too. It has that little curve at one end. Probably a good way to remember it is that you push it the opposite direction of the curve.abscate wrote:It looks like it comes DOWN then back. I would have sworn I pushed my 1999 up and then back.
obayha
Looks like me and JB are going to put things back together. It's something simple to play with. I need simple.abscate wrote:And the broken piece falls into the bowels of the car so it can't be JB welded back.
1998 V70 T5 331,000
If you can find a piece of wood dowel to JB weld inside that it will be a lot stronger
obayha
Already thinking, Threaded rod, with maybe a washer and nut on the end.
Major weekend project.
Shane
Shane
1998 V70 T5 331,000
Titanium rod best
